Adding SDRAMPS to my ramps arduino system, running g code from splic3r, currently running off printerface. Once the run is running off of sd card, does info continue to feed back to printerface in computer? Things like percent done, nozzle temp, things of that sort?
Thank you. I will try out the unit when it gets here, just wanted feedback from someone who had used it. Will your program abort a run or allow pauses?
Theoretically yes.
Practically I've never tried it, I start the print, watch the first layer go down, the unplug the USB connection from the PC and turn it off.
Do not press the disconnect button, it will reset the arduino and stop it printing.
