Well the extruder will have to be calibrated to twice as much.
195? What type are you using? I have 4043D and extrude at 188.
Quoted form the wiki:
"Heater Settings
Depending on which material you use, you should adjust your heat accordingly.
4032D requires higher temperatures and may need to be set as high as 230°C
4042D should extrude at 190°C
4043D 160-220°C around 180 is a good start (see [
ultimachine.com])"
-Nick
