check the resistance of your wires from the tester, put them together and measure the resistance. the wires are often thin that are in the probes. mine are 1.25 ohms for example. take this into consideration when then measuring low resistance, and subtract whatever the resistance of the probe wiring is.
for example my probe wires and leads have a total resistance of 1.25ohms
i get a measurement with my probe wires across the resistor of 6.6 ohms and i subtract 1.25ohms getting 5.35ohms. my resistor is 5.6ohms +/-10% tolerance that is a range of 5.04ohms to 6.16ohms. within my specified limit of operations.
