Would you teach how to make skirt?
Because, the data of my Gcode do not make the skirt.
Therefore figure is not formed on a bed.
Which setting of Slic3r should I set?
I add explanation.
I obtained a Mendel today. I was able to print the Gcode data for attached tests well.
I converted the STL data which I had into Gcode in Slic3r. However, the converted Gcode does not make a correct print on the warmed bed.
I know that a pedestal (=a skirt) consisting of the number layers that are slightly bigger than a print (=figure) is necessary to make a print (=figure) and a bed adhere. However, the G code does not make the pedestal (=a skirt).
Therefore would you teach a method to make the pedestal (=a skirt) definitely?
My expression was incorrect.
Would you teach a method to set Raft?
Edited 3 time(s). Last edit at 01/11/2013 06:36AM by Koichi Hirasawa.
