heatbed mk2 problem
Posted by RicardoGA
heatbed mk2 problem
May 25, 2013 07:50PM
hi I've a problem with the heatbed mk2 it's connected to ramps 1.4 and the power supply is a regulated power switching supply 12v 30a but when i turn on the heatbed the regulated power cut off the power i think is the power supply shortage protection the resistence of the heatbed is 1.4 ohm please helpe to solve this
thanks in advance
Re: heatbed mk2 problem
May 26, 2013 12:44PM
Your problem is more likely the power supply than the bed, unless you have a short on the RAMPS.
May 28, 2013 09:11PM
Found the problem and solved
The problem was the pcb Heatbed this has a short the solutions has changed the pcb heatbed
