I am posting the same email I just sent to taulman about this but thought I would ask here as well.
Hello,
I just got my order in yesterday and was eager to try it out. I started with the 645 3mm nylon (I also ordered the 618).
I had a bit of a hard time starting out, I could not get it to stick down, tried different materials including blue tape, PET film and the backside of copper clad PC board which is fiberglass. It's similar to the Phenolic that RichRap uses and I had some on hand.
I finally got it to stick by printing very slowly (20mm sec) using my .50 nozzle. The .35 that I normally use for ABS just seemed to small as almost nothing came out of it.
I tried printing at 235c and 240c (240c seemed to work) so I printed a coin that I have that has letters in it. The letters were a little wonky (not nice and tight) but none the less it printed.
When I pulled it off the PC board (which was very easy) I touched one of the letters and it came off easily, so I tried another. Before you know it all the letters where laying on my desk and not attached.
So I then tried and was able to fairly easily peel apart the layers of the coin. So there seems to be a serious adhesion issue from layer to layer
I printed with a .50 nozzle, .25mm layer height 240c temp and 20mm second speed across the board.
So you gave any ideas what I might be doing wrong?
