I have been finding that my print quality decreases as a print session goes on; in particular the x axis skips steps and creates a slanted print, in the x direction.
The print on the left was the first print, and although the angle of the photo isnt perfect, the 'side walls' are pretty much vertical.
The part on the right was printed second, about 2 minutes after the first print finished- the side walls have a much more exagerated slant to them.
It is also worth noting that the printer had been running pretty much continuously for 2 hrs before these prints.
Am I thinking along the right lines to suspect the stepper drivers are over heating, and causing the motors to skip/add steps?
The drivers have heatsinks and are uncovered, and in a cold (6°C) garage- is there anything else I can do to aid cooling/reduce heat build up?
Thank you in advance.
Will
open |
download -
(562.5 KB)
