Anonymous User
Rubber drive wheel February 04, 2014 09:05PM |
Re: Rubber drive wheel February 04, 2014 09:17PM |
Anonymous User
Re: Rubber drive wheel February 04, 2014 09:27PM |
Re: Rubber drive wheel February 04, 2014 09:38PM |
Anonymous User
Re: Rubber drive wheel February 04, 2014 09:44PM |
Re: Rubber drive wheel February 04, 2014 10:11PM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: Rubber drive wheel February 05, 2014 02:48AM |
Re: Rubber drive wheel February 05, 2014 03:35AM |
Re: Rubber drive wheel February 05, 2014 03:46AM |
Re: Rubber drive wheel February 05, 2014 10:29AM |
LoboCNC
One other idea is to press the filament into a v-groove in the drive roller - like is done with a V-belt. This will effectively increase the friction and maybe reduce deformation.
Anonymous User
Re: Rubber drive wheel February 05, 2014 11:40AM |
Re: Rubber drive wheel February 06, 2014 12:36AM |
Re: Rubber drive wheel February 06, 2014 05:16AM |
Re: Rubber drive wheel February 06, 2014 09:01AM |
Xabbax
An alternative - wrap the filament around the drive gear for better grip
Drive gear with a 1mm groove cut with a dremel ( [deltaprinter.co.za] )
[attachment 26340 drivegear.jpg]
Re: Rubber drive wheel February 06, 2014 09:19AM |
aduy
someone should try making a drive that uses two flat rubber belts. the belts would run like a tread mill and the filament would be in between the two sets of belts. sorry for the crude drawing. you could use four timing pulleys and two small continous timing belts.
[attachment 26355 filamentdrive.png]
Re: Rubber drive wheel February 06, 2014 10:16AM |
aduy
Re: Rubber drive wheel February 06, 2014 11:11AM |
ShadowRam
aduy
I was thinking of a three gear system to help
WORD OF CAUTION!!!!
Filament slippage is good. It saves your hotend from being blown out and destroyed if there truly is a jam.
Using more force or strength is not always the answer in mechanical design.
There will always be a main point of failure, and you want to be the one choosing where that is.
I'd always prefer my filament to strip than have the brass nozzle blown out of the PEEK on my J-Head.
Re: Rubber drive wheel February 06, 2014 11:25AM |
aduy
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Rubber drive wheel February 06, 2014 08:02PM |
I've got a hunch that that's impossible. I don't know, I'll try increasing my purge in 100mm/s intervals until something happens.Quote
ShadowRam
aduy
WORD OF CAUTION!!!!
Re: Rubber drive wheel February 07, 2014 07:01AM |
Re: Rubber drive wheel February 07, 2014 07:35AM |
Re: Rubber drive wheel February 07, 2014 07:47AM |
Re: Rubber drive wheel February 07, 2014 08:17AM |
Re: Rubber drive wheel February 07, 2014 08:21AM |
Robonz
It did work but suffered from slippage. Stantor says that filament slippage is good. After a lot of experimenetation I would say its bad.
Re: Rubber drive wheel February 07, 2014 08:26AM |
Re: Rubber drive wheel February 07, 2014 11:01AM |
Re: Rubber drive wheel February 08, 2014 04:01AM |
Re: Rubber drive wheel February 08, 2014 04:38AM |
