Anonymous User
Pultrusion not Extrusion February 11, 2014 12:40AM |
Re: Pultrusion not Extrusion February 11, 2014 05:09AM |
Re: Pultrusion not Extrusion February 11, 2014 06:51AM |
Re: Pultrusion not Extrusion February 11, 2014 12:01PM |
Re: Pultrusion not Extrusion February 14, 2014 07:30PM |
How about the UV curing resins? A UV light outside of the extruder shining on the part as it is being printed would allow the resin to set almost immediately and also would not require any heat in the process.Quote
Robin2
I don't think pultrusion is the appropriate word. Pultrusion (see Wikipedia) involves something being pulled through a die and doesn't have to involve the combination of two chemicals. I can't see how a spider could "pultrude" because the component chemicals are unlikely to have any tensile strength until they have left its body and mixed.
However the idea of extruding one or two liquid chemicals which harden when mixed (epoxy and hardner perhaps) or which harden on contact with air (superglue?) is intriguing. Another possibility might be extrude a stiff paste that has sufficient "body" to hold its shape until it hardens.
I think the challenge will be to find something that hardens fast enough but not so fast that it ruins the extruder. And I suspect it will be more difficult as the extruded diameter decreases.
...R
Anonymous User
Re: Pultrusion not Extrusion February 14, 2014 08:15PM |
Re: Pultrusion not Extrusion February 15, 2014 04:48AM |
ohioplastics
The problem with 2 part solutions and uv curing is that it doesn't achieve the necessary "pull" or downward force to bring the resin out of the nozzle. The adhesion to the substrate, the print bed on the first layer and the extruded plastic on the rest of the layers, would need to provide all of the force necessary force to draw the filament out.
Given that that force is extremely small, I think it could only be possible with extremely small filament. However, the advantage would be that it wouldn't require a motor to drive the filament, or it'd use just a small dc motor to get it started.
