All,
When wiring a j-head do you use high temperature wire running the full length from the board to the resistor in the head? It seems like it would be fine just using short lengths of high temp wire between the connector at the head and the resistor. From the connector back to the board I would think that 14 awg auto wire is sufficient. I'm thinking that XT60 connectors are appropriate for this task. That's what I'm using for the connections to the power supply. What are your thoughts?
Diagram to clarify
|Board |=====14 awg wire ~2' (60cm)=====|XT60 Connector|=======high temp wire ~6" (15cm)=====|JHEAD|
Also, do you solder the connection between the resistor and the wire or do you crimp? I've heard some people state that they believe a soldered connection will melt and won't hold up.
There seems to be a mix of different wiring strategies for the jhead. Indeed, I think if you look at videos online you will find that everyone is assembling them differently. Looking for some informed opinions.
Edited 1 time(s). Last edit at 04/05/2014 12:44AM by Dorian.
