Making a Linear Stage June 03, 2014 12:32PM |
Re: Making a Linear Stage June 03, 2014 04:10PM |
Re: Making a Linear Stage June 03, 2014 04:32PM |
Re: Making a Linear Stage June 03, 2014 04:54PM |
ejbantz
If you're already order from robotdigg, they have stepper drivers, motors, arduino and ramps.
Re: Making a Linear Stage June 03, 2014 04:55PM |
cdru
RAMPS isn't necessary if he's just hooking up two steppers. It may make any other use of the Arduino harder with the unused RAMPS functionalty taking up pins.
As to the design, just remember you'll need to compensate on the z-axis when the x-axis moves. Otherwise when X moves, Z will spin up or down. If you are writing custom firmware to just control the movement and moving only one axis at a time isn't a problem, then it's easily solved. If you need to be able to move x and z simultaniously it gets more complicated. A long splined shaft that has beveled bearings that run along it might be a work around, but that may not work with your budget, or materials requirement.
Out of curiosity, what is the experiment box for? Does it have to be sealed or can there be open ports that things are ran through just nothing metal on the inside of the box? If it's the latter, you could afix the motor to the top/bottom/side/whatever for the z-axis.
Re: Making a Linear Stage June 03, 2014 05:02PM |
bluehawk91
ejbantz
It looks like Robotdigg is in located in China.
Do you know the shipping time and cost?
Can't find that information.
Re: Making a Linear Stage June 05, 2014 12:56AM |
