Hi guys, printer was working fine, (ramps 1.4 with mechanical end stops and marlin firmware)
All of a sudden, when I click print, the axis will return to their endstops, including z. The z axis will then raise itself, stutter as though they are fighting something, and then lower itself again approximately 2mm below the bed. I have not changed any settings, there is no z offset set, and I have tried old g-code that I know use to not have this problem.
Any suggestions?
Cheers,
