Voltage Drop at Ramps 1.4 / Heatbed September 18, 2014 04:46PM |
Re: Voltage Drop at Ramps 1.4 / Heatbed September 19, 2014 07:12AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Voltage Drop at Ramps 1.4 / Heatbed September 19, 2014 07:31AM |
Re: Voltage Drop at Ramps 1.4 / Heatbed September 20, 2014 01:56PM |
mantus
so you loose around 1,2V within the RAMPSQuote
Bugo
Power Supply is a Switching PSU 12A 33 A, and i'm reading 12.34 V on output.
did you check the clamps? check if they fit really tight.
Maybe your FET got damaged .... please check the Vds of the FET as well as its Temperature.
Voltage from both sides of D8 with reference to ground.
This last one will give you two voltages: One high, one low. The difference should be the voltage sent to the heated bed. The lower one is the voltage across the FET, the higher one is the voltage across the larger PTC fuse (F2).
The way PTC fuses work tends to be rather annoying when you're at the edge of their current load.
For instance, if the PTC fuse is 11A and you're drawing very close to that (say 10.75A) then it can start dropping volts to reduce the current slightly. It does this as the PTC fuses work internally based on temperature, so if they're already warm the trigger current is reduced.
