Firmware Choice & Setup Issues. Help & Ill be your friend December 05, 2014 03:27AM |
Re: Firmware Choice & Setup Issues. Help & Ill be your friend December 05, 2014 04:14AM |
Re: Firmware Choice & Setup Issues. Help & Ill be your friend December 05, 2014 05:22AM |
Re: Firmware Choice & Setup Issues. Help & Ill be your friend December 05, 2014 02:00PM |
You are correct. You can reverse the rotation by switching the pairs from 1A1B to 2A2B, or in firmware as above.Quote
I took a multimeter to the steppers, and got 2 coils in each (continuity between one pair of wires an an open circuit between the two pairs?) Then wired one coil to 1A1B and the other coil to 2A2B. From what i gather the polarity of the pairs doesn't matter, as long as the pairs are indeed paired correctly?
Re: Firmware Choice & Setup Issues. Help & Ill be your friend December 05, 2014 06:03PM |
