A year of ABS, the year of hell November 18, 2014 08:31PM |
Re: A year of ABS, the year of hell November 19, 2014 11:19AM |
Re: A year of ABS, the year of hell November 20, 2014 06:47AM |
Re: A year of ABS, the year of hell November 20, 2014 07:09AM |
Re: A year of ABS, the year of hell November 20, 2014 08:33AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: A year of ABS, the year of hell November 20, 2014 11:06AM |
Re: A year of ABS, the year of hell November 20, 2014 12:31PM |
Re: A year of ABS, the year of hell November 20, 2014 01:25PM |
jaguarking11
I have not had much truble with ABS, I have not tried PLA as it does not suit my needs. I had a few clogs here and there, and fought stringing etc. etc. But I learned a few things along the way.
1 - measure your filament at least in 10 different places every 30cm or so and get an average. (easy to do as you simply run a caliper to the roll and measure each coil)
2 - if your bed takes longer to heat up than the hot end, preheat the bed first then heat up the hot end. I had more clogging issues due to the filament staying in the hot end for 15 minutes while the bed made it to temp than anything else.
3 - make sure your filament is springy enough. (if you can snap it by hand easily then do not trust it for long prints) It should be fairly flexible.
Concerning #3, I have 1/4 roll of natural ABS that is very fragile, I only print small parts with it.
Re: A year of ABS, the year of hell November 20, 2014 01:49PM |
Re: A year of ABS, the year of hell November 20, 2014 02:41PM |
Re: A year of ABS, the year of hell November 20, 2014 03:30PM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: A year of ABS, the year of hell November 20, 2014 04:38PM |
Dust
A lot of these issues will be due to absolute crap filament. If you pay bottom dollar, you pay for it in other ways.
I've seen many a person struggling to print, you give them some known decent filament and they are printing in minutes!
The second most common cause is crappy hot ends from e-bay or aliexpress. All I can say is get your hot end from a reputable supplier if you don't want a "year of hell"
Re: A year of ABS, the year of hell November 20, 2014 05:18PM |
Admin Registered: 11 years ago Posts: 1,063 |
jaguarking11
Dust
You certainly get what you pay for in this world. However, if your willing to check your parts for tolerances and fit, an e-bay hot end or aliexpress part will do the same job as a more expensive unit. While I understand the frustration with cheap stuff. More often than not aliexpress parts have been totaly worth it. I bought 3 different hot ends from there. I bought a j-head with a .4mm nozzle that printed more abs than anything. When I received it I dissembled it and looked for blockage, dirt etc. I then measured the parts and resembled it. It was worth the price I paid ~24usd..... My second and third hot ends were cheaper than the jhead, they are properly machined and have not had any issues with them. Use common sense here, I had to clean out the back of a nozzle on 1 of 3 heads I bought due to some brass swarf being left behind. Once cleaned and inspected it was properly assembled and in use. The more expensive units are not immune to impurities. Some have found metal and others have found parts of teflon in their "brand name" units that cost sometimes 4-6x the price....
here is the result of a 24 dollar loaded j-head (heater catridge and thermistor included) [www.youtube.com] Now tell me the 60+ dollar unit is better? Note I only print in abs....
Re: A year of ABS, the year of hell November 20, 2014 06:57PM |
Re: A year of ABS, the year of hell December 09, 2014 03:36PM |
Re: A year of ABS, the year of hell December 09, 2014 03:59PM |
Re: A year of ABS, the year of hell December 10, 2014 02:14PM |
dave3d
I only do ABS now. Stronger than PLA and I can use the parts I make outdoors in the weather.
Two things I have learnt in the 18 months I have been printing: the most important things are the hot end, and secondly filament quality. Steer clear of black ABS and you should be OK.
Re: A year of ABS, the year of hell December 10, 2014 02:42PM |
Re: A year of ABS, the year of hell December 11, 2014 09:55AM |
dave3d
jaguarking11:
I can't find a good black. I have wasted my money on 3 different spools now. The first one I bought on Ebay was very cheap and stunk out the living room. I have tried out two other spools from other suppliers and the quality is awful. It did not extrude consistently and the layers delaminated easily. Car bumpers and other ABS parts are recycled now. It all ends up in the mix. All to do with saving the planet.
Other colours are absolutely fine. Black can have a lot of recycled material and can be disguised easily with black pigment.
If you can recommend a good source let me know.
Re: A year of ABS, the year of hell December 17, 2014 11:04PM |
Re: A year of ABS, the year of hell December 18, 2014 12:05PM |
