First Build Suggestions for Semi-skilled Newbie? January 09, 2015 02:39AM |
Re: First Build Suggestions for Semi-skilled Newbie? January 09, 2015 03:26AM |
Re: First Build Suggestions for Semi-skilled Newbie? January 09, 2015 03:30AM |
QFT!Quote
tmorris9
A 3D printer is one of those things you did not know you needed until you have one then you can't imagine living without one.
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: First Build Suggestions for Semi-skilled Newbie? January 09, 2015 09:19AM |
Re: First Build Suggestions for Semi-skilled Newbie? January 09, 2015 12:31PM |
Re: First Build Suggestions for Semi-skilled Newbie? January 13, 2015 12:34AM |
Re: First Build Suggestions for Semi-skilled Newbie? January 14, 2015 09:12AM |
There are kits that are essentially materials only, all the nuts, bolts, screws, etc. So it's not so much a kit ready to assembly, but just a kit of parts already collected. Typically plastic parts are printed but if you have to machine them, I'd double check the design of all the parts to see how conducive they are for subtractive manufacturing. Sometimes there's pockets and channels that may be difficult or impossible to machine.Quote
repraprip
I have to build the frame myself (no kits allowed), and hopefully I will have time to build the extruder head as well.
Threaded rod is SLOW compared to belt unless you have a high lead, but then you lose resolution. Having a slow z-axis isn't usually a problem as it's only moving a fraction at a time, but in the X and Y axis it'll really slow down your printing time. Belts aren't that hard to work with, and some designs don't even use belts. They use fishing line or similar materials instead.Quote
After researching your suggestions I think I'll go with threaded rod design as my experience with belts hasn't been great.
Varies with the printer, what's the object is that is being printed, and the material type. Different materials have different characteristics and peeling, warping, delaminating, initial adhesion, etc all are issues that can happen. The slicing software usually has parameters that control what the desired temperature is for the first layer as well as second and higher layers.Quote
I was wondering if any of you know if the heated table stays on for the whole process or if it is just necessary in the beginning?
Yes. Bigger motors usually require more power and you may have problems with your stepper drivers supplying enough current without overheating. You may also need to adjust your speeds depending on the characteristic of your motor but the software itself, whether you're referring to the slicer or the firmware, will work the same either way.Quote
Also if I put bigger motors will the software still work the same?
Re: First Build Suggestions for Semi-skilled Newbie? January 14, 2015 01:13PM |
