Large envelope printer March 14, 2015 07:31PM |
Re: Large envelope printer March 14, 2015 08:48PM |
Re: Large envelope printer March 15, 2015 07:01PM |
I did find that, but I was hoping to find something a little less proprietary, and a little more DIY. I've read a few posts on forums and blogs with people aiming to complete one for around $3k...
Re: Large envelope printer March 15, 2015 09:46PM |
Re: Large envelope printer March 15, 2015 09:57PM |
the_digital_dentist
What's proprietary about it? Look at the photos and build one.
Re: Large envelope printer March 16, 2015 12:12AM |
Re: Large envelope printer March 16, 2015 05:29AM |
Re: Large envelope printer March 16, 2015 10:47AM |
Re: Large envelope printer March 16, 2015 11:46AM |
jaguarking11
I was thinking about this the other day but with a delta printer with a build volume of about 60cm/60cm/60cm the Height of the printer would be nearly 1.3M at the minimum. Probably around 1.5m in height. Then I sat down and thought about the stability of the frame.
As far as I can think through. I would need some large steel plates for both the top and the bottom. Around 1.5-2cm thick. Then some 40x40mm aluminum tubing to create the frame. Also 3 smaller steel plates to hold the moving mechanism.
Re: Large envelope printer March 16, 2015 12:16PM |
Re: Large envelope printer March 16, 2015 02:24PM |
Re: Large envelope printer March 16, 2015 04:15PM |
Re: Large envelope printer March 16, 2015 07:52PM |
Re: Large envelope printer March 16, 2015 10:33PM |
Re: Large envelope printer March 17, 2015 05:34AM |
Re: Large envelope printer March 17, 2015 10:15AM |
Re: Large envelope printer March 17, 2015 11:39AM |
Re: Large envelope printer March 17, 2015 12:12PM |
Re: Large envelope printer March 17, 2015 07:18PM |
Re: Large envelope printer March 17, 2015 07:25PM |
Zavashier
Why timing chains ? do you need to go on a single way with heavy load ? A 3d printer is the opposite. Timing chains are for conveyors or bikes, or any unprecise application. You can get no precision with them ! Many reasons to don't use that :
- no smooth motion
- large pitch
- weight = low acceleration
- noisy
- needs to be greased often
- needs to be tensionned and controled often
- to much tolerance between links = no precision
Autolevel procedure won't replace a dead flat surface. It's just to measure and compensate the whole bed level position. If your bed makes a cup, you will never print a flat part. Simple as that. As you guess, a dead flat surface is exponentially expensive with size.
Re: Large envelope printer March 17, 2015 07:39PM |
Re: Large envelope printer March 17, 2015 07:42PM |
Re: Large envelope printer March 17, 2015 08:01PM |
the_digital_dentist
If you're talking about a printer in which the bed moves in the Y axis, your biggest problem is going to be controlling the motion of that large moving mass, unless you don't might very low print speeds.
Fully supported rails or linear guides can easily fix the sag problems, as long as the frame of the machine is sufficiently sturdy.
Re: Large envelope printer March 17, 2015 08:51PM |
Re: Large envelope printer March 18, 2015 03:51PM |
Re: Large envelope printer March 18, 2015 05:59PM |
Re: Large envelope printer March 18, 2015 06:19PM |
Re: Large envelope printer March 19, 2015 03:26AM |
pugzor
Hey all,
I've almost finished a delta with a respectable print area (based on AndyCart's Cherry Pi III), but I'm already looking forward to my next project.
I was hoping to build something big enough that could potentially print an engine block. They aren't as big as you'd think. One of the largest in terms of length I'd require would be 70cm long for a large bore straight six. To accommodate a small-ish V8 I think it'd need to be 50cm wide. 50cm height would be more than enough too. I'd also like a design with dual extruders.
Does anyone know of an existing design with those parameters?
Re: Large envelope printer March 19, 2015 08:38AM |
