Afinia filament on Reprap March 23, 2015 10:50PM |
The Premium ABS filament has been designed specifically to the specifications of the H-Series 3D printer, the most important being the 260° Celsius extrusion temperature. The Value-Line filament has an extrusion temperature range between 210 and 250° Celsius. This range allows for broad support among a number of different 3D printers on the market.
Re: Afinia filament on Reprap March 24, 2015 01:11AM |
Re: Afinia filament on Reprap March 24, 2015 09:08AM |
Ah I see, thanks for the info! I'm trying to upgrade to E3D v6 hotend hopefully it'll be able to handle it. Otherwise I'll just eBay it....Quote
ggherbaz
Their premium filament might have some additives that require higher temperatures (most likely nylon)
I have some "high quality " ABS that I can only print from 245 and up, anything under and won't print right, you should be able to print at lower than 260, but don't know if at 225.
Re: Afinia filament on Reprap March 27, 2015 10:18AM |
Re: Afinia filament on Reprap March 27, 2015 05:55PM |
