Reuse BST 1200es 3D Printer platforms? April 10, 2015 01:31PM |
Re: Reuse BST 1200es 3D Printer platforms? April 11, 2015 11:30PM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Reuse BST 1200es 3D Printer platforms? April 11, 2015 11:32PM |
Re: Reuse BST 1200es 3D Printer platforms? April 12, 2015 12:59AM |
Re: Reuse BST 1200es 3D Printer platforms? April 12, 2015 01:02AM |
IMBoring25
When our SST 768 at work won't reuse a modeling base it comes after a bed-leveling routine, so it seems to be because it has decided the base is either bent, twisted, or both. There is likely a limit to how much you can deform the base while removing the parts before it takes a permanent set and your model of machine may even be more critically affected by the heat cycles. It would probably reuse them if you could figure out a way to get them flat again.
