temperature readings April 22, 2015 10:23PM |
Re: temperature readings April 23, 2015 06:26PM |
Re: temperature readings April 30, 2015 03:02AM |
Re: temperature readings April 30, 2015 04:37AM |
Re: temperature readings April 30, 2015 04:45AM |
Re: temperature readings April 30, 2015 12:47PM |
Re: temperature readings April 30, 2015 02:40PM |
Thermistors work by varying its resistance based on temperature. Typically a NTC resistor is used, which means as temps go up, resistance goes down. If you have a loose connection, corroded connector, anything that would add resistance your temp readings can be skewed. Check the resistance at room temp (25 degrees C) and compare that to the data sheet from the manufacturer. For instance, the commonly used Epcos B57540G0502F000 thermistor should be 5k ohm at 25 deg. C.Quote
malemodel
how do i test for bad thermistor wiring - i mean it apparently works. what would a bad wring in this case mean?
Re: temperature readings April 30, 2015 04:55PM |
cdru
Also are you sure you have the correct thermistor selected in your configuration?
Re: temperature readings April 30, 2015 10:04PM |
Re: temperature readings May 02, 2015 04:01PM |
