pins.h help
Posted by trist077
pins.h help
June 04, 2015 04:26PM
still having problem with thermistor reading 208 degrees celsus when hotend cold
i have a mks 2z v1.1 board can i configure in firmware for it to use the other port on the board as have 3 the middle one is for bed thermistor and one is used for thermistor o currently
so can it put in the other port and configure to see if the board may be at fault
Re: pins.h help
June 05, 2015 04:00AM
You can change position of bed and hotend port, to see if the error is still there.
But you canĀ“t print then. It is a good test method to find the error.
-Olaf
PS: Which board did you Chose from the list?
#define BOARDS_H
#define BOARD_UNKNOWN -1
#define BOARD_GEN7_CUSTOM       10   // Gen7 custom (Alfons3 Version) "https://github.com/Alfons3/Generation_7_Electronics"
#define BOARD_GEN7_12           11   // Gen7 v1.1, v1.2
#define BOARD_GEN7_13           12   // Gen7 v1.3
#define BOARD_GEN7_14           13   // Gen7 v1.4
#define BOARD_CHEAPTRONIC       2    // Cheaptronic v1.0
#define BOARD_SETHI             20   // Sethi 3D_1
#define BOARD_RAMPS_OLD         3    // MEGA/RAMPS up to 1.2
#define BOARD_RAMPS_13_EFB      33   // RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Bed)
#define BOARD_RAMPS_13_EEB      34   // RAMPS 1.3 / 1.4 (Power outputs: Extruder0, Extruder1, Bed)
#define BOARD_RAMPS_13_EFF      35   // RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Fan)
#define BOARD_RAMPS_13_EEF      36   // RAMPS 1.3 / 1.4 (Power outputs: Extruder0, Extruder1, Fan)
#define BOARD_DUEMILANOVE_328P  4    // Duemilanove w/ ATMega328P pin assignment
#define BOARD_GEN6              5    // Gen6
#define BOARD_GEN6_DELUXE       51   // Gen6 deluxe
#define BOARD_SANGUINOLOLU_11   6    // Sanguinololu < 1.2
#define BOARD_SANGUINOLOLU_12   62   // Sanguinololu 1.2 and above
#define BOARD_MELZI             63   // Melzi
#define BOARD_STB_11            64   // STB V1.1
#define BOARD_AZTEEG_X1         65   // Azteeg X1
#define BOARD_MELZI_1284        66   // Melzi with ATmega1284 (MaKr3d version)
#define BOARD_AZTEEG_X3         67   // Azteeg X3
#define BOARD_AZTEEG_X3_PRO     68   // Azteeg X3 Pro
#define BOARD_ULTIMAKER         7    // Ultimaker
#define BOARD_ULTIMAKER_OLD     71   // Ultimaker (Older electronics. Pre 1.5.4. This is rare)
#define BOARD_ULTIMAIN_2        72   // Ultimainboard 2.x (Uses TEMP_SENSOR 20)
#define BOARD_3DRAG             77   // 3Drag Controller
#define BOARD_TEENSYLU          8    // Teensylu
#define BOARD_RUMBA             80   // Rumba
#define BOARD_PRINTRBOARD       81   // Printrboard (AT90USB1286)
#define BOARD_BRAINWAVE         82   // Brainwave (AT90USB646)
#define BOARD_SAV_MKI           83   // SAV Mk-I (AT90USB1286)
#define BOARD_TEENSY2           84   // Teensy++2.0 (AT90USB1286) - CLI compile: DEFINES=AT90USBxx_TEENSYPP_ASSIGNMENTS HARDWARE_MOTHERBOARD=84  make
#define BOARD_GEN3_PLUS         9    // Gen3+
#define BOARD_GEN3_MONOLITHIC   22   // Gen3 Monolithic Electronics
#define BOARD_MEGATRONICS       70   // Megatronics
#define BOARD_MEGATRONICS_2     701  // Megatronics v2.0
#define BOARD_MEGATRONICS_1     702  // Minitronics v1.0
#define BOARD_OMCA_A            90   // Alpha OMCA board
#define BOARD_OMCA              91   // Final OMCA board
#define BOARD_RAMBO             301  // Rambo
#define BOARD_ELEFU_3           21   // Elefu Ra Board (v3)
#define BOARD_5DPRINT           88   // 5DPrint D8 Driver Board
#define BOARD_LEAPFROG          999  // Leapfrog
Edited 1 time(s). Last edit at 06/05/2015 04:03AM by o_lampe.
Re: pins.h help
June 05, 2015 11:51AM
33 ramps 1.4
