(solved) Second Extruder has much too high feed rate June 20, 2015 10:37AM |
Re: Second Extruder has much too high feed rate June 20, 2015 03:37PM |
Re: Second Extruder has much too high feed rate June 20, 2015 03:59PM |
Re: Second Extruder has much too high feed rate June 20, 2015 04:03PM |
Re: Second Extruder has much too high feed rate June 20, 2015 04:22PM |
Re: Second Extruder has much too high feed rate June 20, 2015 04:40PM |
Re: Second Extruder has much too high feed rate June 20, 2015 04:53PM |
Re: Second Extruder has much too high feed rate June 21, 2015 03:29AM |
dna
I too changed this:
#define NUM_AXIS 5 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {50*60, 50*60, 2.5*60, 0,0}
Result is the same. :-/
Re: Second Extruder has much too high feed rate June 21, 2015 03:52AM |
GRAYWOLF
dna
I too changed this:
Just a point here,
Changeing those line will not do anything as the "#" means that they are commented out!
Re: Second Extruder has much too high feed rate June 21, 2015 04:52AM |
Re: Second Extruder has much too high feed rate June 21, 2015 04:53AM |
Re: Second Extruder has much too high feed rate June 21, 2015 05:00AM |
o_lampe
tadawson
Uh, that's double *forward* slash. Only MacroSquid uses backslashes . . .
- Tim
My bad, I´m not native english speaking...
Re: (solved) Second Extruder has much too high feed rate June 24, 2015 04:24AM |
