Thermistor problems with e3dv6 May 12, 2015 04:06PM |
Re: Thermistor problems with e3dv6 May 12, 2015 04:41PM |
Re: Thermistor problems with e3dv6 May 12, 2015 06:27PM |
Re: Thermistor problems with e3dv6 May 12, 2015 06:28PM |
Re: Thermistor problems with e3dv6 May 12, 2015 08:02PM |
Re: Thermistor problems with e3dv6 May 13, 2015 03:13AM |
Re: Thermistor problems with e3dv6 May 13, 2015 08:04AM |
Re: Thermistor problems with e3dv6 May 13, 2015 08:42AM |
Re: Thermistor problems with e3dv6 May 13, 2015 11:05AM |
foul_owl
My nozzle diameter is apparently 0.4 mm, since that is listed as the default on the e3d website.
My layer height has generally been 0.3 mm, except the first layer which has been 0.4 mm, so sounds like that is correct.
Re: Thermistor problems with e3dv6 May 13, 2015 11:45AM |
It's usually suggested to keep the maximum layer height to no more than 80% of the nozzle diameter to get sufficient squishing of the layer. So for a .4mm nozzle, no more than .32mm.Quote
vreihen
There's your problem! Draw the 0.4mm circles and stack them. How much contact is there between the 0.4mm layers? I have a 0.4mm diameter nozzle, and run it at 0.2mm layer height (and occasionally 0.1mm layer height on important parts).....
Re: Thermistor problems with e3dv6 May 13, 2015 04:30PM |
Re: Thermistor problems with e3dv6 May 14, 2015 08:30PM |
3dkarma
I have had problems with Slic3r's default extrusion width settings. I got the same delamination problem at the same layer height using Slic3r's default extrusion width. I would suggest changing all of the extrusion width settings to 0.5mm and trying a test print, just to see what you get.
Re: Thermistor problems with e3dv6 July 03, 2015 06:55PM |
