Be prepared but several hours of frustation due to oozing.
The main reason people abandone bowden systems is to avoid these spills of filament or so they can use flexible filaments.
You have to work out how much retraction you need to stop the nozzle oozing.
I did the initial measurement this way:
Extrude a bit of filament and mark it where it enters the extruder.
Release the tension on the filament by disengaging the extruder.
The filament will spring back a bit, in my case around 9mm - this is the initial retraction you need to prevent the nozzle loosing plastic.
From there you can adjust up and down a bit until satisfied.
For obvious reasons the time between extruding and disengaging the extruder should be as short as possible.
And always check the hobbed bolt (or whatever drives your filament) before long prints so there is no plastic stuck in it that might cause the filament to slip.
