This the right place to ask about suggestions? July 16, 2015 04:03PM |
Re: This the right place to ask about suggestions? July 16, 2015 06:52PM |
Re: This the right place to ask about suggestions? July 16, 2015 07:44PM |
Re: This the right place to ask about suggestions? July 16, 2015 08:05PM |
JamesK
Moving the bed in Z is difficult to do well and cheaply (nothing new there then), but it appeals to me too. If I was starting over I would probably try and build a smartrap core. It doesn't exactly meet your requirements - it has printed parts and the kit comes over budget, but I like the approach. On the Prusa i3 front, the P3Steel gets a lot of positive comments.
Re: This the right place to ask about suggestions? July 16, 2015 08:08PM |
garabitu
Hi,new posting in this forum but a intense reader last months. I'm from Spain and have some dificults in english,sorry. Since i was afraid to make a 3d printer from zero i buy one of this all acrilics from Alibaba. Crap,s...t. o wathever you want say. PURE TRASH. Since i only pay 219 $ plus 42$ shiping cost I'I'm happy with the amount of parts i can salvage to make a steel one.
Re: This the right place to ask about suggestions? July 16, 2015 08:20PM |
Re: This the right place to ask about suggestions? July 16, 2015 08:25PM |
Re: This the right place to ask about suggestions? July 16, 2015 09:02PM |
the_digital_dentist
If I may suggest, before you buy into a $300-400 kit, have a look at this to learn a little about what you're giving up to get to that price point. If nothing else it may help you develop a more critical eye toward evaluating different kits before you send someone your hard-earned cash.
Re: This the right place to ask about suggestions? July 17, 2015 05:15AM |
Re: This the right place to ask about suggestions? July 17, 2015 11:58AM |
garabitu
A friend and I buy two of them to make expenses and customs cheaper.
First thing was some little pieces not sending, curiosly not the same in both printers. Since they are things like screws, plastic pillars, a pair of end stops and a bearing we took them from ours scrap box.
Second., nothing about a manual only a pdf not very hepfull. Third issue the all acrilic frame, really a fragile thing. You need to be very caute when screw the parts toghether they tend to break very easy.
Other issue and most important the laser cut is not scuared. There are a slighty angle in the cut along the stiffnes of the acrilic, this supousse you are incapable to get rigt angles within the parts. The adition of this little errors go to the vertical rods and z screw to be inacurate positioned to the point that you cant move the z sttepers in any way. In the vertical frame those innacuracys make a slighty curve puting tension on the x carriage.
Now we are triying to get rigth angles in all the acrilic parts and save the wole thing but here i Spain you can get a 3mm steel frame about 40$ that we think is coming to be the solution.
A I say in the other post in this cheaper price we get good steppers, inox rood, trapezoidal screws, brass nuts, linear bearings ..... aceptable quality.
Ok a long post in a crappy english. Sorry guy.
Re: This the right place to ask about suggestions? July 18, 2015 03:36PM |
My kits x motor mount and idler mount were printed terribly also. I redesigned them with set screws for mounting the x rods. Much easier assembly. They use (4) bearings instead of (2). If you want the STL files for them let me know. Brian.Quote
garabitu
Re: This the right place to ask about suggestions? July 18, 2015 03:38PM |
elwood127
garabitu
[attachment 58354 XCarraigeAssembly.jpg]
