multiple hotend electronics for large printers? July 05, 2015 09:34PM |
Re: multiple hotend electronics for large printers? July 05, 2015 11:53PM |
DC42
The sustained speed for uploading a file to the SD card via the web interface seems to be a little over 170kbytes/sec. The card interface is SDHC, so it doesn't have the speed limitation that Smoothie seems to have when uploading to SD card from the web interface.
Re: multiple hotend electronics for large printers? July 19, 2015 04:45AM |
Re: multiple hotend electronics for large printers? July 19, 2015 04:54AM |
Epop
I don't know anything about arduino other than it seems to be aging... though I've also read Duet is based on it and some say the firmware is a wreck because of it. Though I don't program, it doesn't seem to affect operation. Other than that I haven't seen much comparison between the two that I can remember atm.
I'm running build envelope about half your size with a12v Duet+x4 & PanelDUE using 3-1.75 mm extruders and either a 115v 400w chamber heater or a 115v 300w bed-using the SSR method.(firmware doesn't currently support both, though there have been G codes reserved for it). Longest print to date has been ~7hrs without issue. I've been using it once or twice a week in this almost finished state for a couple weeks is all. on a single extruder maybe a month or two.
The adjustment for 3 heads was rougher for reprap hotends because none of them seem to be designed for multiple setups(adjusting height mainly) so a slip-fit design like the cyclops or kraken would probably be easier than the other options I've seen.
File transfer could also be an issue for you @600mm, Ethernet on the duet... while I prefer it to messing around with WiFi. is slower... a 20mb file takes a min to upload... but you also have the option of just using the SD card.
DC42
RepRap Wiki comparison of electronics just in case you haven't come across it.
Re: multiple hotend electronics for large printers? July 19, 2015 05:43AM |
