ABS sticking to extruder September 09, 2015 04:00AM |
Re: ABS sticking to extruder September 09, 2015 06:46AM |
Re: ABS sticking to extruder September 09, 2015 01:43PM |
Re: ABS sticking to extruder September 09, 2015 04:14PM |
Re: ABS sticking to extruder September 09, 2015 04:21PM |
J-Max
Don't try to jump as fast as that from extreme values.
If you want to calibrate temperature to match your filament need, print a calibration tower.
BUT I believe your problem is not due to extrusion temperature.
Check first the bed adhesion and then do a proper extruder calibration.
++JM
Re: ABS sticking to extruder September 09, 2015 04:24PM |
Re: ABS sticking to extruder September 09, 2015 04:50PM |
Re: ABS sticking to extruder September 10, 2015 02:57AM |
Re: ABS sticking to extruder September 11, 2015 06:01PM |
Re: ABS sticking to extruder September 12, 2015 12:30AM |
Re: ABS sticking to extruder September 12, 2015 08:16AM |
The bed must be set close to the glass transition temperature of the material.Quote
DaveOB
110 seems a bit high. I print abs without problems at 85C bed.
Re: ABS sticking to extruder September 12, 2015 08:40AM |
J-Max
So 110°C is a bit high, but 85°C is realy too low.
With a bed at glass transition temperature, don't cool the part too much with ABS,
or you'll experience wraping even with a proper bed temperature.
I would say cooling fans to 30-50% maximum.
So minimize bridges on your parts.
++JM
Re: ABS sticking to extruder September 12, 2015 11:53AM |
