Z movement noise issue, for firmware specialist and detectives September 26, 2015 05:29AM |
Re: Z movement noise issue, for firmware specialist and detectives September 26, 2015 11:10AM |
Re: Z movement noise issue, for firmware specialist and detectives September 26, 2015 11:35AM |
AlexY
What firmware are you using? In Marlin you only need to change the thermistor number if you're switching hotends, so everything else should stay the same.
Re: Z movement noise issue, for firmware specialist and detectives September 26, 2015 12:24PM |
Re: Z movement noise issue, for firmware specialist and detectives September 26, 2015 01:45PM |
AlexY
Try changing only the max temperature and thermistor number for now; keep the PID settings the same as before and verify that the Z-axis doesn't have problems. Afterwards you can run a PID autotune to get the temperature regulation calibrated.
Also, make sure that your z-axis steps per mm didn't accidentally change during the firmware upgrade.
Re: Z movement noise issue, for firmware specialist and detectives September 26, 2015 08:44PM |
#define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_AXIS_STEPS_PER_UNIT {100.5,100.5,800,800} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {800, 800, 3, 50} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
Re: Z movement noise issue, for firmware specialist and detectives September 27, 2015 04:33AM |
lynspyre
Hey t0bb, can you post the stock firmware that is working great for you?. I don't own a TAZ, but i had Repetier 0.92 on my firmware, and had to move to marlin, and got a similar issue.
I found that Marlin has merged the Max Acceleration from all steppers into a single value shared for them, this cause the Z axis (which requires more steps per unit) to overshoot and spind too fast, causing lot of noise and torque loss.
I had to step down this
to a lower value until i was satisfied with.
Hope this could help you.
EDIT:
P.S.: I don't know if that value can be split into a matrix row, as other values like this
Re: Z movement noise issue, for firmware specialist and detectives September 29, 2015 05:13AM |
Re: Z movement noise issue, for firmware specialist and detectives October 02, 2015 02:05AM |
t0bb
Re: Z movement noise issue, for firmware specialist and detectives October 02, 2015 08:46PM |
t0bb
lynspyre
EDIT:
Hi lynspyre,
here is my stock firmware that works fine- [devel.lulzbot.com]
just open configuration.h file with wordpad
here is the troubled firmware in question- [devel.lulzbot.com]
also open configuration.h
What troubles me is that they tested it on the machine same as mine and it worked for them properly. Something happened with my machine while I was on the wrong advanced firmware for TAZ 5 (I am TAZ 3)
But again if something happened it should have made problems for me on the stock firmware later as well.... a bit confusing..
thanks for the insight though !
