[Help] Capacitive sensor acting weird December 26, 2015 05:31AM |
Re: [Help] Capacitive sensor acting weird December 26, 2015 07:59AM |
Re: [Help] Capacitive sensor acting weird December 26, 2015 10:16AM |
Re: [Help] Capacitive sensor acting weird December 26, 2015 02:38PM |
Re: [Help] Capacitive sensor acting weird December 27, 2015 03:41AM |
frankvdh
If the LED is always on, then the sensor has failed.
These capacitive sensors seem to fail regularly... I've gone through two so far, and now prefer manual height setting.
Re: [Help] Capacitive sensor acting weird December 27, 2015 03:42AM |
'Quote
DjDemonD
It's a normally open sensor so the led should only come on when it is placed next to a surface. Test the sensor first connect negative and +12v leave the signal wire unconnected. The led should be off. Bring the sensor near a surface usually around 2-4mm away the led should come on.
If you now put a multimeter from negative to the signal wire you should be reading 0v when nothing is nearby and +12v when something comes near the sensor. If this isn't working and you have no wiring errors the sensor is faulty.
Wire it to your printer as follows. Connect +12v to your PSU, connect negative to PSU, run the signal wire through a 5v voltage regulator (which needs a ground/0v connection also) and then to your printers z min endstop. Which is the pin nearest the outside of the ramps board.
The marlin configuration might need a bit of messing about with there are two settings endstop logic and pull up resistors. Just try all 4 combinations until you get open when the carriage is away from the bed, and closed when it is close to the bed.
Re: [Help] Capacitive sensor acting weird December 27, 2015 04:19AM |
ishe7ata
I've struggled with it and got it work using the voltage divider. Then realized that it's not sensing the glass but rather the heatbed beneath. So I glued Aluminum Foil beneath the glass bed. Still the results are very inconsistent.
I've to play around with the sensitiviy dial on top a bunch of times while calibrating. Should I just replace the sensor?
