It sounds like there are many fascinating projects... I've let my imagination go here...
There is a sub-forum here where making filament is discussed: [
forums.reprap.org]
I think the biggest problem with creating your own filament from recycled materials will be consistency - creating pure plastic filament with an even diameter from recycled materials is hard. This is a big project in itself. You have to have the right material to start with. It might be perfectly fine plastic - but it may not extrude well, or may shrink terribly, be brittle, or too flexible, etc.
It might be better to start off with a filament maker (as mentioned above) that uses plastic pellets, much cheaper than buying filament and it would give you experience creating filament. Then you could add some recycled plastic (of the right kind) and see if a decent product can be produced.
You are also talking about some high tech materials. You may be able to add specialty materials to your filament pellets when making filament, like the carbon fiber filament that is available. This takes wear resistant nozzles to extrude it, as it will wear out normal nozzles quickly. Creating this kind of filament is also a big project in itself, but it could be an add-on to the project above. These add-in materials would have to be purchased though, unless you can create carbon fiber or graphene in quantity.
Creating a large scale printer that can reliably print large items without them warping is also a huge project in itself. You will need experience creating progressively larger printers.
Creating large high tech objects from a 3D printer that can handle wind loads - using all of the above (recycled) technologies - now you've gone beyond. Most FDM 3D printed parts are not as strong in all directions. Printing large without warping and cracking is very difficult (you need an enclosed and temperature controlled printer to do this for many plastics) You may be able to create cores that you could wind carbon fiber on though.
So, having thought through all that, my suggestion is to create a 3D printing ecosystem. Your students will need to learn how to do every process, but not by re-inventing the wheel. All of this is being done.
1 - Set up a 3D printing lab with a variety of average sized printers, and experiment a lot - experiment with printing larger and larger parts - and strength testing them, using various filament materials you have purchased, or made with your filament bot.
2 - Purchase a filament bot to make your filament from pellets, which can be purchased in bulk. This will give the students valuable experience creating good filament.
3 - 3D printers without CAD is worthless. Set up a Computer Aided Design lab, associated with the 3D printer lab, so that prototypes/parts can be designed, and printed by the students. There is a section here about 3D software, much of which is free.
4 - Make your own, larger filament bots, with the goal of making filament faster and more consistently (better plastics, with an even diameter).
5 - Experiment with shredding and creating compatible recycled plastic pellets that can be added to your filament batches.
Notice that this is step #5, not step #1, because your students need experience making and using good filament of various materials, before using recycled materials. You may want to just create pellets with the recycled plastics, not filament directly. This will allow blending, and production of more consistent filament. This technology can then be spread to various communities, allowing small scale recycling projects, with the filament or pellets used locally - not necessarily only for 3D printing... Note that filament spools will also need to be created.
6 - And finally, experiment with building larger printers (using some parts printed from your smaller printers). This is a more costly undertaking. Focus on sturdiness, reliability, and accuracy. If you only rely on buying your larger printers from someone else then you may get locked into proprietary filament, or you may not know enough about the entire system in order to fix it, improve it, and make more 3D printers.
Making more printers from local materials is a major goal of Reprap.
Anyway, I have rambled enough...
My printer: Raptosaur - Large Format Delta - [
www.paulwanamaker.wordpress.com]
Can you answer questions about Calibration, Printing issues, Mechanics? Write it up and improve the
Wiki!
