RAMPS thermistor table? January 18, 2016 05:39AM |
Re: RAMPS thermistor table? January 20, 2016 08:11AM |
Re: RAMPS thermistor table? January 20, 2016 11:58AM |
I use 11 as well but found that my heated bed now jumps 10f higher when it used to be pretty steady. I suppose I will have to manually play with D and P but just odd that a real Epcos 3950 didn't have this issue.Quote
DjDemonD
I use 11 for this thermistor. Which isn't on the list in configuration.h in all marlin versions.
Re: RAMPS thermistor table? January 21, 2016 05:10PM |
Re: RAMPS thermistor table? January 21, 2016 09:14PM |
Supposedly the 32bit controllers do NOT use tables they auto adjust based on the values I posted above. Too bad RAMPS doesn't have that but this 5-10c over shoot is very bad and I have to do something to calm that down.Quote
DjDemonD
I'm sure many copied thermistors are not very accurate, it's a shame there isn't a thermistor autocalibrating function but I suppose in order to do this you need a really accurate way of measuring the temperature and it seems a thermistor is far from that.
Re: RAMPS thermistor table? January 24, 2016 01:23PM |
Re: RAMPS thermistor table? January 24, 2016 04:31PM |
