calculating Vref for A4988
Posted by rizulthkr
February 14, 2016 03:35AM
What is the formula for calculating the Vref for an A4988 pololu driver.?
Is it Vref= current per phase(I)/ 2.5
or is it Vref= (curent per phase/.7 ) /2.5 {in case of full steps}
I am also having problem of layer shifting
Re: calculating Vref for A4988
February 14, 2016 04:37AM
The formula is:
Vref = 8 * I * R
where I is the peak phase current you want (normally 50% to 80% of the rated phase current of the motor) and R us the value of the sense resistors. R will be either 0.1 or 0.05 ohms depending on your drivers.
I prefer to use all-in-one controller boards that let you configure the motor current in software.
