Bowden vs direct setup February 23, 2016 03:54PM |
Re: Bowden vs direct setup February 23, 2016 04:12PM |
Re: Bowden vs direct setup February 23, 2016 09:57PM |
usslindstrom
I'm not the source of info here, but my experiences fall inline with what you were describing.
MANY iterations of extruder combos on my i3, both bowden and direct feed. I do prefer direct feed myself, due the oozing of the nozzle (I'm currently on a dual-extrusion build on the thing) - but there in lies the rub, where the weight of the direct feed dual-extruder makes me print quite a bit slower.
I may explore converting it to a bowden again in the future.
Regardless of any of this - I feel your pain in the jams. After my 3rd or 4th J-Head from Ebay, I gave in and decided no more "half-measures". I ended up grabbing this:
[printrbot.com]
For each of the extruders on my i3. It made THAT much of a difference (never once had a single jam since) - I ended up grabbing that assembly for my 2 other printers as well. One of which, is a kossel mini kit with an e3d v6. It's never jammed using that setup.
The "gear-head" extruder, mixed with the e3d v6, it's pretty close to the cost of the whole kits from Ebay, so the cost is definately not anything to take lightly. That being said, all 3 of my printers haven't jammed since using it. - Just my 2 cents.
Re: Bowden vs direct setup February 24, 2016 01:17PM |
Re: Bowden vs direct setup February 24, 2016 02:16PM |
icefire
Well, my e3d v6 is genuine. Bought from an authorized reseller and not off ebay.
Back to the subject, my hot end and consequently the extruder do get jammed from time to time. The hot end is properly cooled. Do you think that switching to direct setup would improve this?
Re: Bowden vs direct setup February 24, 2016 02:38PM |
icefire
Re: Bowden vs direct setup February 24, 2016 03:26PM |
Re: Bowden vs direct setup February 25, 2016 09:47AM |
Re: Bowden vs direct setup February 25, 2016 10:05AM |
Re: Bowden vs direct setup February 26, 2016 10:13AM |
dc42
I have a genuine E3Dv6 and a Bowden tube more then 600mm long. I was getting the occasional hot end jam, caused by the filament forming a bulb at the end of the Bowden tube. Here's how to avoid it:
2. Don't retract filament too far too fast. When unloading filament, retract the first 20mm very slowly. If you have a retraction command in your end gcode to avoid the filament oozing while the hot end cools down, make it a very slow retraction.
Re: Bowden vs direct setup February 28, 2016 07:01AM |
Re: Bowden vs direct setup February 29, 2016 08:51AM |
Re: Bowden vs direct setup February 29, 2016 09:37AM |
