bed level sensor trouble February 29, 2016 02:21PM |
Re: bed level sensor trouble March 02, 2016 06:58AM |
Re: bed level sensor trouble March 14, 2016 07:07PM |
Re: bed level sensor trouble March 14, 2016 09:28PM |
Re: bed level sensor trouble March 15, 2016 08:20AM |
Re: bed level sensor trouble March 16, 2016 07:31PM |
Re: bed level sensor trouble March 16, 2016 10:03PM |
Re: bed level sensor trouble March 17, 2016 02:03PM |
Re: bed level sensor trouble March 17, 2016 07:41PM |
Re: bed level sensor trouble March 17, 2016 10:26PM |
DjDemonD
Pnp sensors work by grounding the signal pin, so a NC sensor outputs 12v (5v with divider) until triggered then it outputs 0v. This logic is set to false in marlin.
Npn sensors connect the signal pin to the +v when triggered so output 0v open and 12v triggered, so they use true logic in marlin.
Re: bed level sensor trouble March 18, 2016 05:20AM |
Re: bed level sensor trouble March 18, 2016 06:22AM |
DjDemonD
The PNP type ground the signal, the NPN type energise the signal. So the reality is PNP can be attached without voltage dividers, but you need internal pullups.
DjDemonD
There would be a large market opportunity for someone who could manufacture a sensor of this type specifically for 3d printing, it would work on 5v. It would have a reasonably long detection distance i.e. 8mm, it would be able to be triggered using induction or capacitance, to work with the widest range of bed surfaces.
Re: bed level sensor trouble March 18, 2016 06:32AM |
Re: bed level sensor trouble March 18, 2016 04:42PM |
Re: bed level sensor trouble March 18, 2016 05:28PM |
Re: bed level sensor trouble March 18, 2016 05:39PM |
Re: bed level sensor trouble March 19, 2016 05:32PM |
Re: bed level sensor trouble March 20, 2016 05:40PM |
Re: bed level sensor trouble March 20, 2016 08:32PM |
Re: bed level sensor trouble March 20, 2016 10:33PM |
Re: bed level sensor trouble March 21, 2016 04:12AM |
nebbian
DjDemonD,
So for an NPN sensor, you connect the 'load' between the +V and signal, as the sensor will switch signal to ground.
Re: bed level sensor trouble March 21, 2016 05:01AM |
DjDemonD
What's important is that everyone gets it the right way around so that people asking for help on the forum with sensors get accurate information on how to connect them and setup their printers.
Re: bed level sensor trouble March 21, 2016 06:51PM |
Re: bed level sensor trouble March 21, 2016 07:11PM |
Re: bed level sensor trouble March 21, 2016 07:25PM |
Re: bed level sensor trouble March 21, 2016 07:43PM |
Re: bed level sensor trouble March 21, 2016 09:21PM |
Re: bed level sensor trouble March 22, 2016 06:50AM |
Re: bed level sensor trouble March 22, 2016 07:56AM |
Re: bed level sensor trouble March 22, 2016 08:48AM |
