XYZ Motion control without connecting extruder tool head
Posted by Mohan Muthusamy
June 06, 2016 11:31PM
Hello,
Good day!!
Could someone help me to get XYZ motion working for lulzbot taz 5 printer?
I don't want to connect extruder tool head to the printer and on disconnecting that, it throws "MIN TEMP" error on LCD.
On referring forums , I can see that editing configuration.h file ( Marlin Firmware ) would do the above. But I'm unsure about disabling extruder motion.
Thanks in advance
-Mohan
Re: XYZ Motion control without connecting extruder tool head
June 07, 2016 12:02AM
If you unplug the e stepper the controller will not notice (while off or you will damage the stepper driver)
Also if you remove the E stepper driver the controller will not notice that either. (Also while off)
Both will disable E extruder stepper
Re that thermistor, I just wire a 100K resistor over the thermistor inputs. The printer then thinks its 25c all the time.
Its quite hard to remove temperature stuff from firmware, especially if you have a LCD (Last time I looked)
June 07, 2016 12:33AM
Just connect the thermistor -- no need for the rest of the plugs.
June 07, 2016 11:55AM
Thanks Dust and Frank , I will try this out and let you know..
