Reprap kit 3d printer kossel mini kit w/auto level for Ro stock delta
Posted by jhlee1994
July 26, 2016 12:37PM
Hi guys, I just bought this kossel mini delta auto level from eBay. I'm facing problem at slic3r and cura setting. Does anyone know how to set these software for this 3d printer?
Re: Reprap kit 3d printer kossel mini kit w/auto level for Ro stock delta
July 31, 2016 12:56PM
You should try KISSLICER.
For DELTA & KOSSEL type 3D Printer KISSCLICER Software works much better. Try it . Google it
Setting Slic3r & cura Kossel Printer will merely waste your time.
I have assembled 3 machines of kossel all run well the KISSlicer software.
If you need some help in settings of KISSlicer , do let me know. I have loads of setting
July 31, 2016 04:30PM
jhlee1994
The main thing you need to do is to configure the slicer so that (0,0) is the centre of the bed instead of at one of the corners. Otherwise, slicing is just the same as for a Cartesian printer. I use slic3r and S3D to slice models for my delta.
August 01, 2016 10:56AM
Ok, can kisslicer resolve my elephant foot defect and layer shifted defect?
Edited 1 time(s). Last edit at 08/01/2016 10:56AM by jhlee1994.
August 03, 2016 03:09AM
Hi sir, if I want to fix a heatbed into it, what size suppose I buy and how to wiring it?
August 12, 2016 09:53AM
Ok, angeline. So how to set the setting for kisslicer?
