error in setting up RepRap i3 - configuration.h location
Posted by mizar5
September 10, 2016 09:00PM
Hello. I just got this i3, and was trying to set it up following the configuration manual. The attached shows the error reported when arduino tries to compile.
When I extracted the REPRAP_GURU_MARLIN_V.2 files there was no direction as to where to extract them, so I must have extracted them to the wrong location. What is the right location? Thanks
Mizar
Re: error in setting up RepRap i3 - configuration.h location
September 11, 2016 03:07AM
all files should be extracted to same directory,
arduino normally will open each file in a new tab, you only have one tab, so I suspect you only extracted the one file.
September 11, 2016 01:04PM
Make sure you are opening the file with .PDE or .INO.
September 11, 2016 08:53PM
Thanks for the help.
The files are organized as shown.
Other than the Marlin ino file, I did not find any ino files that weren't in the Arduino library as examples
Did not find any pde files.
