Nozzles sizes are getting finer... October 19, 2016 09:14AM |
Re: Nozzles sizes are getting finer... October 19, 2016 10:09AM |
Re: Nozzles sizes are getting finer... October 19, 2016 11:03AM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Nozzles sizes are getting finer... October 19, 2016 01:03PM |
Re: Nozzles sizes are getting finer... October 19, 2016 01:06PM |
Re: Nozzles sizes are getting finer... October 19, 2016 03:25PM |
DragonFire
Don't see why it's a typo, 0.1mm are available in quantity... but to be honest, Chinese don't have great reputation for build quality.
[www.aliexpress.com]
Re: Nozzles sizes are getting finer... October 19, 2016 04:57PM |
Re: Nozzles sizes are getting finer... October 19, 2016 05:08PM |
Re: Nozzles sizes are getting finer... October 19, 2016 07:10PM |
Re: Nozzles sizes are getting finer... October 19, 2016 07:42PM |
Re: Nozzles sizes are getting finer... October 19, 2016 09:56PM |
Re: Nozzles sizes are getting finer... October 20, 2016 12:45AM |
Re: Nozzles sizes are getting finer... October 20, 2016 02:49AM |
That is true to a degree, extrusion needs less force if the inner shape of the nozzle isn't to steep. I found that out when i started using airbrush nozzles. At the same nozzle diameter the airbrush nozzles needed a lot less force to push the filament through. Ultimately however the nozzle opening is the deciding factor. While i have airbrush nozzles with 0.2mm diameter i don't use them. The gain in precision is not worth the hassle and speed reduction at all.Quote
Rlewisrlou666
I think the key is in the gradient/pitch/angle of the nozzle bore.
If you can work out the best way to transition from 3mm/1.75mm to 0.01mm or what ever size nozzle you want to achieve without having steps or at the very least make the steps as small as possible, it'll in theory make things easier.
Looking at how the nozzles are made the majority are just 2mm bore with a 0.03mm hole at the very end.
If you could make a nozzle that has a conical hole from 2mm down to 0.01mm the nozzle would handle the flow of filament easier than tried to squeeze 1.75mm of molten plastic that is being constantly fed through a 0.01mm hole.
Re: Nozzles sizes are getting finer... October 20, 2016 04:00AM |
Re: Nozzles sizes are getting finer... October 20, 2016 04:55AM |
Re: Nozzles sizes are getting finer... October 20, 2016 01:33PM |
Re: Nozzles sizes are getting finer... October 20, 2016 03:25PM |
Re: Nozzles sizes are getting finer... October 20, 2016 03:28PM |
Re: Nozzles sizes are getting finer... October 20, 2016 03:37PM |
Re: Nozzles sizes are getting finer... October 20, 2016 03:38PM |
Re: Nozzles sizes are getting finer... October 20, 2016 03:40PM |
Re: Nozzles sizes are getting finer... October 20, 2016 03:46PM |
Re: Nozzles sizes are getting finer... October 20, 2016 05:47PM |
Re: Nozzles sizes are getting finer... October 20, 2016 10:03PM |
Re: Nozzles sizes are getting finer... October 20, 2016 10:41PM |
Re: Nozzles sizes are getting finer... October 21, 2016 02:52AM |
Re: Nozzles sizes are getting finer... October 21, 2016 03:40AM |
Re: Nozzles sizes are getting finer... October 21, 2016 08:09AM |
VDX
... with small to microscopic dimensions you have to change pretty much (if not all) of your tooling behaviour -- I've done this sort of jobs since some ten years now and have a nice assortment of tools and "remains" at home, so I can use them for my DIY themes too
But then too - one of my longest wishes/ideas after school was to setup a kind of "homebrew nanotech" ... seems to work now
Re: Nozzles sizes are getting finer... October 21, 2016 09:45AM |
Re: Nozzles sizes are getting finer... October 21, 2016 12:34PM |
