I have recently installed an E3D Cyclops and am having huge problems with leakage into the cold areas and then blockages. I'm looking for advice, please.
I am printing PLA and insert both filaments when the heatblock is cold. I then allow it to heat up and feed material through from both extruders as far as possible. After heating, printing is OK when one feed is used but when it changes over to the other filament it refuses to print. Upon inspection I generally find that the unused side has formed a plug in the heatblock and is stuck solid.
Why is this happening? Thinking it may be leakage past the PTFE tube I have changed this on both sides, I have ensured that the PTFE ends are straight and at right angles. I have tried higher and lower temperatures but all of these have had little to no effect.
Any ideas, please?
Thanks.
Richard
