Synchronicity in interesting ideas February 09, 2017 08:06AM |
Re: Synchronicity in interesting ideas February 09, 2017 08:33AM |
Re: Synchronicity in interesting ideas February 09, 2017 10:09AM |
Re: Synchronicity in interesting ideas February 09, 2017 10:15AM |
Re: Synchronicity in interesting ideas February 09, 2017 11:19AM |
Re: Synchronicity in interesting ideas February 09, 2017 11:48AM |
There is no lock, it is a tight fit and all acceleration forces work perpendicular to the slot.Quote
Lykle
Ah yes, I see.
How does it lock into place?
And in the background is a different print head?
Re: Synchronicity in interesting ideas February 09, 2017 12:38PM |
Re: Synchronicity in interesting ideas February 09, 2017 01:40PM |
prot0typ1cal
One observation, doesn't look like there's adequate wedge to cam clearance to remove the hot end. A larger cam may be required.
Re: Synchronicity in interesting ideas February 09, 2017 03:14PM |
JamesK
prot0typ1cal
Isn't that why there's a flat on the side of the cam?
Re: Synchronicity in interesting ideas February 09, 2017 07:12PM |
Re: Synchronicity in interesting ideas February 11, 2017 01:40PM |
Check our site.Quote
prot0typ1cal
Oh yea, what flexible drive do you recommend for the nimble?
Re: Synchronicity in interesting ideas February 11, 2017 02:06PM |
Lykle
I was thinking of adding a torsion spring to keep the cam closed, not sure if it is needed. Simple add.
Re: Synchronicity in interesting ideas February 12, 2017 01:57AM |
