Smoke detector using endstop circuit. June 06, 2017 04:12PM |
Re: Smoke detector using endstop circuit. June 06, 2017 06:06PM |
Re: Smoke detector using endstop circuit. June 06, 2017 07:57PM |
Re: Smoke detector using endstop circuit. June 07, 2017 09:17AM |
newbob
Here's an idea:
have smoke detector relay connected to GFCI outlet that 3D printer is connected to. When smoke is detected, relay shunts hot to ground (through current limiting resistors) triggering GFCI protection. Simple and independent of 3D circuitry that could be on fire and unable to process relay input in software.
Re: Smoke detector using endstop circuit. June 07, 2017 10:37AM |
Dancer
newbob
Here's an idea:
Thats not nice to do a power short, just to do Switch off.
But you are on the right way. Security always has to be Independent from the System to secure. So just use the relay to completely Switch of the Printers power (at the Input of the power supply).
Re: Smoke detector using endstop circuit. June 08, 2017 03:46AM |
Re: Smoke detector using endstop circuit. June 08, 2017 10:22AM |
Re: Smoke detector using endstop circuit. June 08, 2017 11:19AM |
DjDemonD
Tried and tested
[forums.reprap.org]
I'd agree with others who have commented before no fire safety system should be running off the microcontroller which could be in a fault state when you need it to work.
Re: Smoke detector using endstop circuit. June 08, 2017 02:42PM |
DjDemonD
Tried and tested
[forums.reprap.org]
