Humidity? July 06, 2017 04:25PM |
Re: Humidity? July 06, 2017 04:38PM |
Re: Humidity? July 06, 2017 04:56PM |
I live right off of the Mississippi river and over the last 4 years I just can't print in the summer and the only thing I can think of is the humidity. Even a brand new roll I can't use but come the cooler weather where the humidity drops to below 50% and I just don't have any issues.Quote
Floyd
Not sure. I live in Florida where humidity is only 80% or so.
I dont store my ABS in boxes or anything and they print well.
Re: Humidity? July 06, 2017 05:47PM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Humidity? July 06, 2017 06:01PM |
Well, I don't think that because ABS loves being in a heated chamber and actually is the best way to print ABS.Quote
VDX
... this could be changed viscosity and "macro-molecular behaviour", caused by the higher ambient temperature and so slower cool-down too ...
Re: Humidity? July 06, 2017 06:13PM |
Re: Humidity? July 06, 2017 06:21PM |
I do not print in a heated chamber so open air printing. Windless day, or night, sitting in the same spot and in the summer something causes the print to lift and be ruined whereas in the winter the same print will easily succeed. Only two things change and that would be the ambient temp and the relative humidity.Quote
VDX
... do you print with heated chamber?
You have 2 or more different ambient conditions - humidity and temperature (or better temperature-gradient after extruding), air pressure, ...
Some years ago I had to solve a problem with different behaviour of a glue-dispenser between morning and noon - this was caused by varying temperature-gradients inside the glue reservoir while dispensing -- so not exactly your problem ...
Re: Humidity? July 06, 2017 06:35PM |
Re: Humidity? July 06, 2017 07:23PM |
I have to eliminate the storage part of that because that does not change and the RH inside the storage box is enclosed with rechargeable desiccant and a digital RH meter to tell me when to recharge them. I also have tried brand new filament and the same end results and in brand new I mean I purchased it and cut open the bag, removed its desiccant and slapped it on my printer immediately with the same result. I store it away until winter and it prints then store it back where I pull that same roll out of the dry box in the summer and forget it but come winter I will not have any issues with that filament. Based on all of that I have to eliminate the filament, or its storage, as any part of this issue.Quote
VDX
... could be both or even a sort of relative dependency - warping and delamination is mostly connected to temperature, not humidity ... but can be influenced by storage conditions too, what's mostly defined by long term humidity conditions.
Other possible factors are the viscosity and extrusion speed (pressure, "caught" stress) and the cooldown time and curve-shape from printing to ambient temps ...
Re: Humidity? July 07, 2017 09:53AM |
Re: Humidity? July 07, 2017 03:03PM |
Re: Humidity? July 07, 2017 08:53PM |
I have and it did not help but the cardboard box isn't sealed and it doesn't dry anything out and lets not forget that the hotter it is the more moisture the atmosphere can hold and the RH goes up so in a nice hot box it would probably be even worse if humidity is the real culprit.Quote
PDBeal
Have you tried printing with a big cardboard box over the printer itself? You said its not a heated chamber, but if it was enclosed the temperature of the bed and hotend would dry the air inside the chamber to a point that might rule out the humidity option. And I'm not suggesting you spend a ton of money trying it out, but would offer a large cardboard moving box would be large enough to cover most printers and work as a trial to semi-enclose a printer.
Re: Humidity? July 07, 2017 08:57PM |
If I could get it to stay stuck to the heated bed I would have no other issues. Hot + rain for 10-15 mins every single day = forget it.Quote
DjDemonD
Don't know about humidity but its hot in the UK right now, and both of my well calibrated machines have needed 110-115% extrusion multiplier to print ABS normally. Can't figure that out...
Re: Humidity? July 08, 2017 07:50PM |
Re: Humidity? July 10, 2017 08:29AM |
Re: Humidity? July 10, 2017 01:07PM |
54% is low for this time of year but in this room the RH on my meter was 74% (I guess the national weather service's meter is at the airport while I am closer to the Mississippi river) as are our temps since we should be in the upper 90s and lower 100s (weather is funky this year) so I have no idea and AC is out of the question. I am baffled.Quote
DjDemonD
The thing is I wouldn't say 54% RH was a high number.
How about air conditioning?
Re: Humidity? July 11, 2017 11:02AM |
Dark Alchemist
. . . I do believe and that is the medium holding down the print. I use glue stick, hairspray, etc... and those are water soluble and in the summer it is basically sitting in water (that is in the air). My purple Elmer's glue stick never wants to dry... so I think that the glue is just letting go because it never attains a good bond to the glass thanks to all of the humidity.
