Filament diameter compensation April 30, 2017 05:32AM |
Re: Filament diameter compensation April 30, 2017 08:46AM |
Re: Filament diameter compensation April 30, 2017 09:02AM |
Re: Filament diameter compensation April 30, 2017 10:37AM |
Re: Filament diameter compensation April 30, 2017 11:12AM |
Re: Filament diameter compensation April 30, 2017 01:16PM |
RGN01
The reason I take this approach is simplicity - I slice the item with the 'nominal' filament size and can then save the GCODE for future use, making it easy to reprint it later using filaments that vary in size.
I do this quite a bit, often making the same item in different colours of filament - these can vary quite a bit in diameter so the approach of amending the flow multiplier works well. Effectively slice once and then make any necessary changes at print time. To date I've been doing this intuitively, increasing the flow rate by trial and error - now I can do it with a bit more logic behind it. Now that I have this table I will simply write the multiplier number on the spool after calculating it.
Works for me - and may help others who may also be very interested in the approach you mention.
Richard
Re: Filament diameter compensation April 30, 2017 01:43PM |
Re: Filament diameter compensation April 30, 2017 02:01PM |
Re: Filament diameter compensation April 30, 2017 02:49PM |
Re: Filament diameter compensation April 30, 2017 03:06PM |
Three minutes? What took you so long?Quote
RGN01
3 minutes with Excel doesn't quite hit the 'worked so hard on' scale for me but, hey, I was just trying to help others with a handy, easy, free way to do something. I really didn't expect a lecture!
Different strokes for different folks
Richard
Re: Filament diameter compensation April 30, 2017 03:11PM |
Re: Filament diameter compensation April 30, 2017 04:37PM |
Re: Filament diameter compensation April 30, 2017 05:22PM |
Re: Filament diameter compensation April 30, 2017 06:49PM |
Re: Filament diameter compensation May 01, 2017 02:49AM |
Re: Filament diameter compensation May 01, 2017 09:23AM |
Re: Filament diameter compensation, % of area? July 23, 2017 09:43PM |
