Information needed on leveling sensor technologies. January 05, 2018 06:03AM |
Re: Information needed on leveling sensor technologies. January 06, 2018 01:52AM |
Re: Information needed on leveling sensor technologies. January 06, 2018 06:08AM |
Trakyan
Well, to be honest I can't think of another commercially available piezo sensor kit. I haven't heard of too many hobby hacks using one either, so it's definitely uncommon from my point of view. That being said, I quite like it since it's a sensor with zero XY offset from the nozzle and doesn't require tuning to get it to trigger at the proper z height. I can't think of a big name printer that uses this method.
You could try referencing what other high end manufacturers use. Prusa uses an inductive sensor, ultimaker an IR sensor, aleph objects use a contact sensor with the corners of the bed, ditto for zortrax. Printrbot used capacitive sensors, I think they moved to inductive but I'm not sure. All of this should be available from the source files which you can link to or at the very least a feature or spec sheet. Anecdotally, I seem to hear and see much more about inductive sensors than any other type. Most chinese kits that include autolevel seem to use an inductive sensor or occasionally a BL touch.
Re: Information needed on leveling sensor technologies. January 06, 2018 10:33PM |
Re: Information needed on leveling sensor technologies. January 07, 2018 08:18AM |
leadinglights
There are also two Chinese companies selling copies of Moriquendi's circuit in the most blatant plagarism I have come across.
Re: Information needed on leveling sensor technologies. January 07, 2018 01:48PM |
Moriquendi
You developed the circuit, I just put it on a PCB and manufactured it.
Idris
Trakyan
I recall a video done by Tom saying the printrbots he used had a capacitive sensor.
And you're right, to be honest I had a quick look for some sources when I was writing up my last post and couldn't find much if any information beyond "we have bed leveling". You could try some video interviews/reviews since they often mention exactly what type of sensor the machine uses. Tom in particular usually goes into sufficient detail, but I don't know if that is cite-able.
Re: Information needed on leveling sensor technologies. January 07, 2018 07:32PM |
