AC silicone heating mat Red, Yellow, Blue? June 19, 2018 10:13AM |
Re: AC silicone heating mat Red, Yellow, Blue? June 19, 2018 11:19AM |
Re: AC silicone heating mat Red, Yellow, Blue? June 19, 2018 11:22AM |
Re: AC silicone heating mat Red, Yellow, Blue? June 19, 2018 12:14PM |
Turtle_Cat
I've never seen this before but the fact that it's labeled for two voltages is a clue. Between two wires, say, A and B, you'll get a resistance appropriate for the rated wattage at 110v. Between B and C, you should see about twice that resistance, which would give the appropriate wattage at 220v. This is extremely important because if 220v were applied to the 110v side of the heater, it would likely burn up in short order, heating twice as fast as expected.
In short, none of the wires are ground, they are two separate heater circuits. Devices which do not have a metal chassis typically do not include a ground wire, for future reference.
Re: AC silicone heating mat Red, Yellow, Blue? June 19, 2018 01:01PM |
Re: AC silicone heating mat Red, Yellow, Blue? June 19, 2018 02:17PM |
Re: AC silicone heating mat Red, Yellow, Blue? June 19, 2018 04:21PM |
Re: AC silicone heating mat Red, Yellow, Blue? June 19, 2018 05:11PM |
dc42
You are running the heater at half power. To get full power with 110V supply, connect red and yellow together, and connect one wire to red+yellow and the other to blue. But you may find half power sufficient.
