Need some serious help with an external mosfet. July 19, 2018 04:00AM |
Re: Need some serious help with an external mosfet. July 19, 2018 04:14AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Need some serious help with an external mosfet. July 19, 2018 07:54AM |
With bang-bang 255 it still got hot enough to burn flesh.Quote
VDX
... check the RDSON resistance and threshold value uf the new type.
MOSFETs stay cool even with high currents, if 100% switched ON/OFF (as used in bang-bang controlling) ... but heat up with much lower currents, if "hold" at a level (switching gate voltage too low) or used for analogue controlling with PID ...
Re: Need some serious help with an external mosfet. July 19, 2018 08:11AM |
Re: Need some serious help with an external mosfet. July 19, 2018 08:40AM |
Being from China no references given but someone clued me in. The diagram shown from the seller's site (every seller shows the same diagram) has the wiring hooked up wrong. Do NOT use the BED out from the controller to the BED in on the external fet use the SIG side. He suggested that and I tried it and the over heating is gone. With so little documentation on these things even the diagram on how to use it is wrong. I am not sure what the BED side is for but I do know it isn't for our controllers to it. Our suspicion is that it is maybe for an analog voltage of some type and possibly of 5v maximum.Quote
VDX
... look into the datasheet of the MOSFET which activation/switching voltage it needs -- if same or more than your driving voltage, then it will heat ...
