*HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 20, 2018 11:48PM |
//============================================================================= //============================== Movement Settings ============================ //============================================================================= // @section motion /** * Default Settings * * These settings can be reset by M502 * * Note that if EEPROM is enabled, saved values will override these. */ /** * With this option each E stepper can have its own factors for the * following movement settings. If fewer factors are given than the * total number of extruders, the last value applies to the rest. */ //#define DISTINCT_E_FACTORS /** * Default Axis Steps Per Unit (steps/mm) * Override with M92 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 4000, 94.69 } /** * Default Max Feed Rate (mm/s) * Override with M203 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_MAX_FEEDRATE { 12, 12, 0.16666, 25 } /** * Default Max Acceleration (change/s) change = mm/s * (Maximum start speed for accelerated moves) * Override with M201 * X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]] */ #define DEFAULT_MAX_ACCELERATION { 1500, 1500, 75, 7500 } /** * Default Acceleration (change/s) change = mm/s * Override with M204 * * M204 P Acceleration * M204 R Retract Acceleration * M204 T Travel Acceleration */ #define DEFAULT_ACCELERATION 1500 // X, Y, Z and E acceleration for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts #define DEFAULT_TRAVEL_ACCELERATION 1500 // X, Y, Z acceleration for travel (non printing) moves /** * Default Jerk (mm/s) * Override with M205 X Y Z E * * "Jerk" specifies the minimum speed change that requires acceleration. * When changing speed and direction, if the difference is less than the * value set here, it may happen instantaneously. */ #define DEFAULT_XJERK 15.0 #define DEFAULT_YJERK 15.0 #define DEFAULT_ZJERK 0.4 #define DEFAULT_EJERK 4.0
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 01:46AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 02:47AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 03:08AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 03:28AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 04:27AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 04:38AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 05:15AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 05:34AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 05:44AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 07:03AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 08:27AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 09:29AM |
Re: *HELP NEEDED FOR TOO HIGH FEEDRATES SETTING IN PRINTER??* August 21, 2018 10:31AM |
