Reprap Melzi version 2.3 board printer March 01, 2022 04:52PM |
Re: Reprap Melzi version 2.3 board printer March 01, 2022 08:40PM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: Reprap Melzi version 2.3 board printer March 02, 2022 12:19PM |
Sketch uses 93784 bytes (72%) of program storage space. Maximum is 130048 bytes.
Global variables use 4249 bytes (25%) of dynamic memory, leaving 12135 bytes for local variables. Maximum is 16384 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x56
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x72
Problem uploading to board. See [support.arduino.cc] for suggestions.
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, [www.bdmicro.com]
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: reading input file "C:\Users\konst\AppData\Local\Temp\arduino_build_817383/Repetier.ino.hex"
avrdude: writing flash (93758 bytes):
Writing | ################################################## | 100% 29.32s
avrdude: 93758 bytes of flash written
avrdude: verifying flash memory against C:\Users\konst\AppData\Local\Temp\arduino_build_817383/Repetier.ino.hex:
avrdude: load data flash data from input file C:\Users\konst\AppData\Local\Temp\arduino_build_817383/Repetier.ino.hex:
avrdude: input file C:\Users\konst\AppData\Local\Temp\arduino_build_817383/Repetier.ino.hex contains 93758 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 27.49s
avrdude: verifying ...
avrdude: 93758 bytes of flash verified
avrdude done. Thank you.
Re: Reprap Melzi version 2.3 board printer March 02, 2022 07:52PM |
Re: Reprap Melzi version 2.3 board printer March 02, 2022 07:59PM |
## Sanguino W/ ATmega1284 or ATmega1284P 16MHz sanguino.menu.cpu.atmega1284p=ATmega1284 or ATmega1284P (16 MHz) sanguino.menu.cpu.atmega1284p.upload.maximum_size=130048 sanguino.menu.cpu.atmega1284p.upload.maximum_data_size=16384 sanguino.menu.cpu.atmega1284p.upload.speed=115200
Re: Reprap Melzi version 2.3 board printer March 02, 2022 08:45PM |
19:40:11.274 : Detected EEPROM version:20
19:40:11.274 : Z jerk was too low, setting to 0.70
19:40:11.274 : Free RAM:12130
19:40:11.680 : SD init fail
19:40:11.727 : SD initialization failed.
19:40:11.727 : Do not reformat the card!
19:40:11.727 : Is the card correctly inserted?
19:40:11.727 : Is chipSelect set to the correct value?
19:40:11.727 : Does another SPI device need to be disabled?
19:40:11.727 : Is there a wiring/soldering problem?
19:40:11.727 : errorCode: 32
19:40:11.727 : Printer reset detected - initializing
19:40:11.727 : start
Re: Reprap Melzi version 2.3 board printer March 02, 2022 09:20PM |
Re: Reprap Melzi version 2.3 board printer March 02, 2022 10:22PM |
9:40:11.274 : Detected EEPROM version:20 19:40:11.274 : Z jerk was too low, setting to 0.70 19:40:11.274 : Free RAM:12130 19:40:11.680 : SD init fail 19:40:11.727 : SD initialization failed. 19:40:11.727 : Do not reformat the card! 19:40:11.727 : Is the card correctly inserted? 19:40:11.727 : Is chipSelect set to the correct value? 19:40:11.727 : Does another SPI device need to be disabled? 19:40:11.727 : Is there a wiring/soldering problem? 19:40:11.727 : errorCode: 32 19:40:11.727 : Printer reset detected - initializing 19:40:11.727 : start
M115 SENDING:M115 ok 0 FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Mar 2 2022 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3 CapROGRESS:0 Cap:AUTOREPORT_TEMP:1 Cap:HOST_RESCUE:1 Cap:EEPROM:1 Cap:AUTOLEVEL:0 Cap:Z_PROBE:0 CapOFTWARE_POWER:0 Cap:TOGGLE_LIGHTS:0 CapAUSESTOP:1 CapREHEAT:1 Cap:EMERGENCY_PARSER:1 Printed filament:515.12m Printing time:5 days 3 hours 27 min PrinterMode:FFF
Re: Reprap Melzi version 2.3 board printer March 02, 2022 10:28PM |
Re: Reprap Melzi version 2.3 board printer March 02, 2022 10:44PM |
Re: Reprap Melzi version 2.3 board printer March 02, 2022 11:29PM |
M115 SENDING:M115 ok 0 FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Mar 2 2022 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3 Captongue sticking out smileyROGRESS:0 Cap:AUTOREPORT_TEMP:1 Cap:HOST_RESCUE:1 Cap:EEPROM:1
Re: Reprap Melzi version 2.3 board printer March 03, 2022 12:51PM |
SD init fail SD initialization failed. Do not reformat the card! Is the card correctly inserted? Is chipSelect set to the correct value? Does another SPI device need to be disabled? Is there a wiring/soldering problem?No card is present btw.
