Hi, I have enabled filament runout on Marlin which usually parks the nozzle at the specified location and then proceeds to perform purging commands.
But, when I use the rescue print option after the print is stopped due to power failure, parking doesn't happen on filament runout. The print head remains at the same location and other actions for filament runout proceed as usual. My guess is the G27 command which parks the nozzle requires Z to be homed, which doesn't happen after the print is rescued. Is there any way to override this? Or can the commands to be executed on filament runout be changed?
The location change is important because otherwise the purging may ooze filament over the part.
Any help would be appreciated, thanks!
