stephen george Wrote:
> Triffid_Hunter () said
> don't quote me on this, but IIRC that starch
> plastic is hygroscopic, so it swells
> up and goes moldy after a while unless you live in
> a desert.
> 1) Can you paint it?
> 2) Could you use it as a filler ie. ABS outside
> with a solid IIRC centre.
IIRC is an acronym for "If I Recall Correctly" not the name of the plastic.
Those things would probably work, but only permanently if nearly airtight (and definitely water-tight).
